Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
No engine light on dash
having problem engine light will not turn on with key on have two of the same trucks one does the other does not and i cant read the codes
Это хороший вопрос?
Счет 0
3 Комментариев
miz4getful, See Brandon B. and oldturkeys answers above or Re POST year, make, model,engine, transmission and complete question so we, here at ifixit can answer your question effectively.
из
@lpfaff1 really? Another Canuck! Well, greetings from an expat.
из
Thanks for the greeting oldturkey03, all the leaves are down, you know what comes next, have a great day.
из
Добавить комментарий
1 ответ
Выбранное решение
miz4getful, check the bulb for missing/loose/burnt out(exchange it for a known good working one and check the instrument cluster back side for damage, burn mark,corrosion, solder joint break, etc. and if OB2 port is not working check your cigarette lighter fuse for being blown. Good luck.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
miz4getful буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 118
