The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
107вопросов Показать все
My phone won't turn on
Hi, when I try and turn on my phone, it jut stays in the "Samsung" page. I even left it over night, but it's the same
Это хороший вопрос?
Оценка 29
25 Комментариев
Hi my 2015 j1 wont charge keeps saying use samsung charger iam i have cleaned usb port with that spray stuff
из
Hi,my Samsung Galaxy j1 ace phone hung and suddenly went off and has refused to come on...For about 24hours now..... What do I do?
из
hi my phone doesnt turn on at all, I tried removing the battery and hold the power button but still doesnt work. It doesnt even go into download or recover mode. what should I do???
из
hai my j100h when power going2 recovery mode
из
I tried but it just wont star at all
из
Показать 20 больше комментариев
Добавить комментарий
8 Ответов
Выбранное решение
Or if you do not want to lose data flash correct firmware from sammobile via odin software and hope that it boots. If it doesn't boot then wipe+data / factory reset will be done which requires losing all user data on the phone.
Был ли этот ответ полезен?
Оценка 13
13 Комментариев:
I already did it. but again it still does not open. why is that?
из
Stuck on white Samsung logo or the animated logo?
из
i think this kind of problem of samsung unit isa a big problem for samsung users now...
из
Thank you, my phone is good as new.
из
Need some help i have samsung j100 ml and i flash it with the exact firmware then it says pass but after it it wont turn on anymore, even download mode, as well as charging. How to fix it? Can you help me please?
Please pm me asignar45@gmail.com
из
Показать 8 больше комментариев
Наиболее полезный ответ
Do a factory restore, pull the battery out and put it back in to ensure it is off, Press and hold the Power+Volume up+Home buttons at the same time. Release the Power button when the Phone vibrates. Continue to hold the Volume+Home buttons until the Android logo appears. From the Android system recovery screen, select wipe data/factory reset.
Оценка 13
14 Комментариев:
@hortman see told you I'd vote for this
из
Hello can someone help me. my samsung galaxy j1 is not working before it is stuck on bot loop i factory reset then after that its always going to download mode then it wont turn on even i charge it i was even trying to go to the recovery mode but its really not working pls... Someone help me btw the battery is really flat its theres no bump
из
i have done factory restore but still its not opening
из
@hortman didn't worked at all man, &&^& this stock rom I downloaded on Sammobile.
из
i've tried this but nothing happens, it just stays black
из
Показать 9 больше комментариев
please help me…
my samsung galaxi j1 SMJ100H wont turn on…
it wont start up. even if i charged it don't show if its charging or not its just blank and nothing i understand what hapend. it also don’t show samsung logo….
help someone fix it……
Оценка 2
2 Комментариев:
try taking the battery out, leaving that for about 10 minutes. while the battery is out, make sure there is no dust or liquid in your phone. put the battery back in, plug your phone in, and hold down the power button for around 30 seconds. that should work, as I had the same problem.
из
i have tried it but it is not helping
what should i do???
из
if your phone is stuck like that, it might be because one of your cards are loose (SD, SIM) so just take off the back, take out the battery and check your cards. if they are in properly, carefully and slowly put the battery back in. that may fix it :) that fixed my phone with the same problem
Оценка 0
2 Комментариев:
I did it but it not work on my samsung j1 ??
из
I too have done all this but silly Samsung phone remains a corps. Resurrection is not in the cards
из
samsung j1 mini prime.
My phone full start,
But power button not work.
After 2 minute phone automatic restart and stuck logo problem.
I flashing odin app but not working.
Оценка 0
3 Комментариев:
mine is doing that too
из
It might be becoz u have not done all the steps correctly . Mine was also doing the same
из
got this problem too even if battery is being replaced: will restart for about 5 to 7 minutes or less and after restart the samsung startup logo blurred or won't turn on again
из
hello my samsung j1 mini prime sm-j106f stuck on bootloader after then it turns of and turn on by its self when i want to make a hard reset below the intrution it show some erros and failed like: E:failed to mount /cache (invalid argument and E:cant mount /cache/recovery/log it show those this again and again
Оценка 0
hi my samsung j100 wont go to recovery or download mode even after pressing the buttons it just turns on and stay at the samsung logo and it stays there, please help
Оценка 0
so nothing to do with that I think it's over my phone can't wake up again
Оценка 0
Добавьте свой ответ
Miranda Creegan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 74
За всё время: 65,537
