Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Why Does my Reception Keep Dropping Out after Refurb of Chassis
Hello all,
I am posting to ask why the reception in my refurbished iphone 6 keeps dropping out?
The iphone had the entire chassis replaced as the old one was too badly bent & damaged.
Is it possible the after market chassis+parts are to blame for the reception errors?
Or is it possible from the previous drop, the reception components on the logic board broke? Would the either work 100% or not at all?
Any help is appreciated , thanks!
Это хороший вопрос?
Оценка 1
3 Комментариев:
Maybe from the dropping. Did you changed the housing? Maybe one of the antennas plugs is not connected or not seated connected.
из
I changed the housing to a non-OEM housing, it had signal issues. I switched to an OEM housing, it still has signal issues. I think its to do with the logic board. Is it fixable ? ;(
из
There is most likely a missing antenna screw that connects to the housing. OR you need a new dock connector OR- now im not 100% sure about this but - maybe a ground connection to the dock connector? Can someone correct me if the last statement is completely wrong?
из
Добавить комментарий
3 Ответов
Your iPhone 6 housing actually acts as an antenna. It's designed in a way to work perfectly with the design of the board itself. Having an aftermarket housing can easily reduce signal strength.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Ive replaced many housings.... I have never had this issue.... It IS possible, but I'm gonna say not as likely as a bad transplant
из
There is most likely a missing antenna screw that connects to the housing. OR you need a new dock connector OR- now I'm not 100% sure about this but - maybe a ground connection to the dock connector? Can someone correct me if the last statement is completely wrong?
Asumming the antenna cable is connected and is not faulty itsself
Оценка 0
1 Комментарий:
All screws are in the right place. and I even moved the logic board back over to an OEM chassis/parts which still give the same effect. So I believe the damage is done from the drop. WHO SPECIALISES IN LOGIC BOARD REPAIR?!
из
Check this flex to be correctly connected and the copper field clear.
https://d3nevzfk7ii3be.cloudfront.net/ig...
Оценка 0
Добавьте свой ответ
ZsTech будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 63
