Repair information for the Nintendo 64 Controller, model number NUS-005. This controller was released in 1996, for use with the Nintendo 64 Game Console.
9вопросов Показать все
Analog stick - Nintendo 64 Controller
Hi all,
My analog stick of mine controller is not working fine anymore. I found replacements on the internet. I found 2 different version.
I got version A in my controller. Can I solder version B in my controller?
Thanks in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
From a bit of quick research, it appears that it should work fine. Just make sure that your pin connectors line up. Beyond that, it looks like it'll be okay to swap them out.
Best practice would be to install the new thumbstick and before closing it up, test out the controller to ensure that the new thumbstick reacts properly to the game.
Был ли этот ответ полезен?
Оценка 0
I'd say it's a bit risky to add one of those into your controller, because if you got a warranty for it (IF YOU ONLY GOT IT A SHORT WHILE AGO that is) you have to hack into your controller to install the analog stick, and opening it up usually voids the warranty. Also, I've heard that the replacement analog sticks aren't exactly the best. Look in the video below
https://www.youtube.com/watch?v=o3GYtAyR...
Оценка 0
Добавьте свой ответ
Uas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 751
