Big Wheel — это тип трехколесного велосипеда, обычно изготовленного из пластика, с увеличенным передним колесом, который расположен очень низко к земле.
Steering column is stiff
I recently put together a kids big wheel and the steering column is very stiff and will hardly turn. Obviously this isn't something that is adjustable given the set up, but I need simple solution so my three year can steer it. Thanks!
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Try adjusting the height of the handlebars by loosing the screw in step #5 of this PDF and lifting slightly till it turns freely then tighten it back down:
originalbigwheelparts.com/images/bw_assy_instructions_pictoral.pdf
Был ли этот ответ полезен?
Счет 2
4 Комментариев:
Kristina Johnson, This may also help, take the column back apart and apply a little/ thin coating of Vaseline on column and reassemble. Good luck.
из Поделиться
Neither of the above helped a bit. Cannot be steered by a child.
из Поделиться
Item is a piece of junk.
из Поделиться
Agree, the Big Wheel has been unused for over a year. Every few months my kids and their friends get on it and just as quickly get off. I would greatly appreciate someone sharing a fix if there is one out there
из Поделиться
To any parents who bought this for their kids for Christmas and are running into this problem - the solution is candle wax!
Simply apply a thin layer of wax to any surface that rubs in the steering assembly (underside of the handlebars, front fork spindle, inside the hole the spindle goes through, etc.).
I was a little skeptical given the apparently unsuccessful petroleum jelly suggestion, but gave it a shot anyway, as I've used candle wax to lubricate wood in the past.
Not sure how long the effects will last, but it works great so far!
Счет 0
Добавьте свой ответ
Kristina Johnson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 15
За последние 30 дней: 44
За все время: 2,319
