Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
My tab does not turn on?
It was fine till last night. When i woke up in the morning, it was gone. It was low on battery last night and i thought it shut down due to low battery. I put it in charge but it does not show any charging sign. I kept it for few hours in charge, still no sign. I tried to turn on, but it will not. I even tried to go to recovery mode, that too not shows up. It may be the display problem but it neither vibrate on long press power button (turning on/off).
Good solution will be appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
I would first suggest removing the back casing from the tablet to gain access to the battery connection on the motherboard. Then disconnect the battery from its connection on the motherboard. Let the battery sit disconnected for a few minutes then plug the battery connector back into the motherboard. Then see if it will now charge or turn back on normally. I do not know exactly why this works, but this has helped bring back many Samsung tablets I've seen that appear to be lifeless. I assume its an issue with battery calibration software used by Samsung or something along those lines, which disconnecting the battery may reset. You can follow the beginning of this guide to assist in disconnecting and reconnecting the battery. Samsung Galaxy Tab A Battery Replacement
If that does not work there may be another issue such as a faulty battery, charge port, or something else causing the issue.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Suman Chapagain буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 188
