Endless boot loop after RAM install
I'm trying to help my sister-in-law by upgrading RAM and adding an SSD to her late 2009 21.5" iMac. I have successfully managed this in my own machine and created a Fusion Drive.
I installed 4x4gb RAM that match specs of machine and then installed Sierra to the computer. I ran into problems booting the machine after that (never successfully made it into Sierra). Now, the machine boots endlessly, progress bar makes it about 3/4 of the way through then it reboots.
I have (in no particular order):
Put the original 2x2gb RAM back in: no change.
Booted to Recovery mode: reboots before it gets to recovery options.
Booted to Internet Recovery: reboots at Apple logo after getting past spinning globe.
Booted to external drive with a bootable Sierra installer on it (both an external HD and an SD card): crashes and reboots at same spot as before.
Booted in safe mode: get error message and reboot.
Booted to my 27" iMac running Sierra as the Target Disk: kernel panic and reboot (have error message if important)
Looking for any help of where to go from here. All I want is a clean install on the machine with the SSD in place of the optical drive (using the iFixit mount). At this point, I'd even settle for just the SSD if need be, without the Fusion Drive I'd planned. Thanks in advance for any info any of you can help with.
Это хороший вопрос?
7 Комментариев
Who's SSD are you using here?
из Dan
Your systems specs: iMac 21.5" 3.33 GHz Core 2 Duo (Late 2009)
из Dan
Can you double or triple check your RAM seating and RAM-speed? I had similar problems recently with a newer iMAC which was rebooting even after I put back everything back to original. The fault in myside was I put a RAM module not perfectly in the slot. Best is put only one RAM (closer to screen) and start there by you can find the error.
из Edward C
Edward C - I suspect I know whats up here and its not the RAM ;-}
But to be sure I need to know what the exact SSD drive being used.
из Dan
I plan to put in a Crucial SSD, but haven't installed yet. I was doing ram and upgrade to Sierra, then planned on putting in the ssd and creating a Fusion drive. Should I make a bootable Sierra drive on the ssd and then install? I'm concerned because it's not booting to an internal or external right now, so don't know if a new drive will solve the problem. Seems like the issue lies somewhere other than the drive, no?
@moeller22: I'll check the RAM later tonight, putting a single 4gb stick in one slot at a time.
из Aaron Peterson
Показать 2 больше комментариев
