No backlight,rest of the screen and tablet seems to be working well
Hi, got a tab 3 with not working backlight. Seeing the screen changes under a lamp is bit challenging but seems that the rest is working just fine. Touchscreen,wifi,sound,buttons light,all seems to be working fine. Tried restarting,factory defaults ,changing the screen brightness settings, charging to 100% with no luck.
Is there some simple solution to checking out if the wires/LED light work before ordering complete new screen or checking the bugs on mainboard? Allegedly no water or falling damage sustained.
Thanks in advance for every help.
Это хороший вопрос?
2 Комментариев
hi Shrubbery,
I do face the same problem than you did.
And i cannot succeed to find an inverter for yoga tab3 on the net.
Can you tell me if u could solve this matter and how you did it?
Thanks
Arno
mandalaandco at the rate of yahoo. fr
из bollyogi
no, unfortunately i haven't. when i tried googling the thing I found some "solution"but it involved microsoldering the motherboard. i tried to exchange the ribbon cables without success.
из Shrubbery
