The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
73вопросов Показать все
Why is my system memory use 7 gb out if 8 gb?
my phone is samsung galay j2 model number is SM-J200G
THE PROBLEM IS THAT MY PHONE IS USED 7 GB FROM OUT OF 8 GB I CANT USE MY PHONE PROPERLY.
WHEN I READ THE SPECIFICATION OF THE PHONE IT USES AROUND 3.4 GB
SO WHAT IS THE PROBLEM?
Это хороший вопрос?
Оценка 6
Добавить комментарий
4 Ответов
Выбранное решение
Because of formatting, and what is used for the OS. The amount of physical memory installed is 8 GB, but you lose a few hundred megabytes due to formating, and a gigabyte or two for the OS. This is true of all storage devices. Totally normal. The rest of the free storage is used for apps, games, music etc. Luckily, that phone has an sd card slot so you can add more memory with this.
Hope this helps!
Был ли этот ответ полезен?
Оценка 4
Наиболее полезный ответ
Do you have a lot of apps ? Or pictures or music on the phone. They all take up space . Get yourself a micro sd card and move your stuff there and free up the internal memory. Hope this helps
Оценка 5
1 Комментарий:
My friend thanks for your answer but It's not what I ask. In the storage area when you enter in seeing the phone storage space there are a lot of lists and one of them is system memory. It means that run the whole device. It takes 7gb out of 8gb how is it possible?
This is my question.
P.s I didn't install any softwares on it except it's factory version and also I have sd card the photos and videos are in it.
из
I have a 8gb galaxy on5 and there is 4. Something gb used in my system memory in my internal storage, there is gotta be a way to delete whats in that system memory, no matter how many times i reset my phone
Оценка 3
1 Комментарий:
No onextra is telling a bottle system memory and that is.main problem occupied lot of storage space.
из
I have also this problem.But i can fix it.
Factory Reset your mobile and try it.
I 'm ok now.
Thank
Оценка 1
1 Комментарий:
I have samsung j2...after software updating my phone storage is full even my phone is empty.update software consumed all storage(99%) what should I do now
из
Добавьте свой ответ
FAYZ JEMAL будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 16
За последние 30 дней: 88
За всё время: 30,804
