The Nikon Coolpix L20 is a compact digital camera produced as part of Nikon’s Coolpix line.
6вопросов Показать все
Latches for battery door
How can I replace latches for battery door on camera?
Update (01/05/2017)
How can I fix latches on battery door? Nikon Coolpix L20 Camera not used a lot & like new but latches broke.
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
@lje you will have to replace the battery cover. This guide will show you how to split the camera to get to it Here is how to remove the door from the housing.
the door itself is available at places like this and others.
Был ли этот ответ полезен?
Оценка 3
@lje , Linda, Use the links below to see how to fix/replace your battery door on your Coolpix, video is not your exact model, I do believe the battery door is the same. If not comfortable doing repair, have a good camera shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=cebruSCl...
http://www.ebay.com/sch/Nikon-Digital-Ca...
Оценка 2
Where i can get this Nikon coolpix battery cover L 20
Оценка 0
Добавьте свой ответ
Linda Musnuff будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 10
За последние 30 дней: 39
За всё время: 2,825
