First generation of Citroen's supermini car.
30вопросов Показать все
Reversing light comes on occasionally when breaking
Since having my reversing lights repaired at a garage, they come on occasionally when I break. Drivers behind me are worried! I can't recreate the fault when stationary tho. Help!
Это хороший вопрос?
Оценка 0
2 Комментариев
does the reverse light work when you have it in reverse gear??
из
Yep, reverse light works when in reverse gear and I can see it when it's stationary
из
Добавить комментарий
1 ответ
Выбранное решение
Hi,
If the work was carried out recently to repair the reversing lights by a garage, there should be some sort of guarantee on their workmanship, provided by them, even if it is only for 30 days etc.
Take the car back to them and explain the problem and show them as well (hopefully the problem will happen when you do this) and ask them to check it out, as it is causing problems for you..
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
sophie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 116
