What are theses pins inside the phone?
I had to change my battery and screen of my Z3 Compact, he work from some days, but I when I got to change the rear camera, I lost the metal bracket that goes around the camera and now I phone wont turn on anymore... Just red light when charging..
That golden pins prevent the phone from being charged or turned on? Because as I lost the metal bracket so I think two of them arent pressed.
Это хороший вопрос?
3 Комментариев
Have you looked at the full tear down on iFixit?
Sony Xperia Z3 Compact Teardown
из S W
That picture doesn't offer much detail... Try to retake it. I don't see any pins.
из George A.
Hello, thank you all for the attention. I attached a new picture, please see the circle marked with the number "1" .. There was a metal bracket that supposed to hold the camera that I lost.
By the way, in the circle number "2" where was a plastic that jump out (the same that you can find 1 cm up) , but (I think) that unless I pretend to use the magnetic charger that shouldn't be a problem..
If the problem is the lack of this two pieces, knowing that I can't find to sale both, what can I do to make the phone turn on again?
Thank you a lot!!!
из José Silva
