Sometimes problem touch screen
Hello, I have a problem. My 5 c works perfectly then sometimes stop taking certain keys. If I rotate horizontally then I put it vertically, it works, then after a few days the problem occurs again, I tried to mount another original display but the problem sometimes recurs. Not even a tweet in dfu mode solves the problem
Это хороший вопрос?
9 Комментариев
I disassembled the original one from an iPhone.
из Luca Ciclisti
Was the phone dropped or liquid damaged? Was there some type of impact to the phone before this behavior started?
из Stephen Elliott
No liquids, the phone did not have a big impact.
из Luca Ciclisti
Luca, this issue sounds like a digitizer issue. Have you done replacement of screen on your 5c? If so what kind of screen did you put on it? Some screen manufacturers make cheap screen that barely work.
из Eyob Grainge
I might try doing a reflow at ic
из Luca Ciclisti
Показать ещё 4 комментариев
