The Microsoft Surface Pro 2 is a Tablet/Laptop fusion that was released in 2013. The Surface Pro 2 is the successor of Microsoft's Surface Pro and uses Windows 8.1 through Windows 10.
40вопросов Показать все
LCD connector damaged during replacement.
my device is way past due warranty, so i changed the ssd size, i did.
Everything went ok but i damaged the LCD connector in the process. some of the pins are uncovered and one fell off.
that made the touch screen have a midline deadzone.
http://i.imgur.com/Uhseal8.jpg
what can i do to fix it? only one pin is missing and it's from the top uncovered ones.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
same issue. Any tips? what is the connector pin size? 35 or 70?
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
suhaib будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 90
