Why is my iPod6 show the logo then shut off and continue to do this?
So on thanksgiving day I accidentally forgot my iPod was in my pocket and brought into our hottub then after about half a minute later I remembered my iPod was in my pocket, I took it out and pressed the power button to see if it still worked, but before I got In it was at 2%, so I put into rice about 5 minutes after getting out and left it in the rice for about 10 days, then when I plugged in after 10 days it just keeps showing the apple logo four about 7 seconds then shuts off and does the every time I plug it into a wall outlet, but When I plug it into my laptop it didn' t turn on at all so I tryed plugging it into my tower but It still didn't work, can someoine please help, I have no idea what's wrong with it,
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Выбранное решение
You've got water damage. You'll need to take it apart and clean the logic board with 90% isopropyl alcohol. Rice doesn't do anything, to help fix this, so you could probably just cook the rice, and eat it. You're iPod is in a boot loop, after you clean it, you may need to restore it. The reason you're only getting the boot loop from the wall charger is because then you're getting full power. Computer charging only gives 30%-50%
iPod Touch 6th Generation Logic Board Assembly Replacement
Electronics Water Damage
http://allrecipes.com/recipe/84137/easy-...
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
superkitty8600 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 398
