No power after digitizer and LCD replacement
I have an ipad mini 2 that will not power on after replacing the digitizer and lcd screen.
I replaced the digitizer first and tested, at the time everything came back up.
The next day I came back to reassemble and nothing came on. I then replaced the lcd screen with a new one and still nothing.
There is no indication of backlight fuse or filter damage. They look fine.
It makes no sound, and doesn't respond to touch at all.
When plugging into itunes, the device is recognized but I can't unlock it because of the requirement to give permission from the ipad screen.
Any ideas on what the issue may be?
Thanks in advance.
Это хороший вопрос?
Try shining a flashlight close to the screen and tell me if you see anything
из Justin R
It will be very dim.
из Justin R
I have done that as well. There is nothing.
из Autumn Pies
