The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
service engine soon light
how do I reset' Service Engine Soon' light
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@scull801 , Steve, Turn ignition switch to on without starting the engine. Press the options button on the instrument panel until the service light is displayed, then press reset/set button to show the reset confirmation screen.
Turn ignition off. Repeat if message comes back.
Use the links below for more info.. Good luck.
https://www.youtube.com/watch?v=FF9e44tQ...
http://www.ehow.com/how_7325389_reset-so...
https://www.youtube.com/watch?v=98KaMGzw...
Был ли этот ответ полезен?
Счет 2
The "Check Engine" or "Service Engine Soon" light indicates there may be a repair or replacement of your engine or transmission. It means there is more than a routine repair or service requirement, and instead, a system failure to the fuel, transmission, ignition, or emissions.
Счет 0
Добавьте свой ответ
Steve C буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 58
За всё время: 18,182
