15 inch "Desk Lamp" iMac G4 700MHz M6498 PowerMac 4,2
32вопросов Показать все
Trying to reinstall OS
Hello everybody (again).
I previously posted about a fault with my g4 not turning on, which has now been sorted. But now I'm faced with another problem!
I bought it from eBay, faulty and the fault has been sorted. But now I don't have the login password and I'm having trouble reinstalling the OS. I have all of the original discs but when I insert the install disc and hold C nothing happens, it just loads up to the login screen. I'm using a Windows keyboard but that's never been a problem in the past. My guess is a faulty CD drive but before replacing that I was wondering if anybody has any tips for me? Maybe a way of creating a usb drive that I can install the OS from? Or another idea is to install the OS on an external drive and clone it to the internal drive, but I'd need directions on how to do this. I have plenty of iMacs and Macbooks lying around if that helps?!
I'd love for an answer to my problem as its in brand new condition and has every piece of original packaging, etc..
Thanks in advance
Это хороший вопрос?
Оценка 1
1 Комментарий
It's a wired keyboard which is responsive in the login screen so I don't think that's the problem. I'm fairly sure I tried holding alt, but I'll give it another go tomorrow. Even if no CD is detected will holding alt load anything up? Or will it just boot as normal? Thanks for your help
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Is it a wireless keyboard? My iMac will not go to the boot selection screen with a wireless keyboard. I have to plug in a wired one. Try to press and hold alt to get to the boot menu and then select the cd.
Был ли этот ответ полезен?
Оценка 1
Hi
You can install snow leopard on a usb
Maybe try that
Thanks
Оценка 1
From my experience working on these, it’s commonly the DVD/CD drive that goes bad, I’ve had to replace several of them.
  1. You could try is booting from a Firewire 400 external hard drive with OSX installed on it by holding down the alt/option key when starting up.
  2. Or you could optionally connect it to another Mac that also has a Firewire 400 port and put that Mac in “Target Disk Mode” by holding down the T key at boot.
I know this post is old, but this is for anyone else that might have this issue in the future as it might be of some use to them.
Оценка 0
1 Комментарий:
yep, these era of machines will ONLY boot from firewire devices so using a USB drive is not possible. This behavior only changed recently as I recall because my 2008 late model MB Pro still would only boot from firewire devices
из
Добавьте свой ответ
Andy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 824
