Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
Back camera doesnt work even after replacement
I bought this phone for what i thought would be an easy fix n flip.
The power button and back camera werent working.
I replaced both parts. However, while doing so, much to my horror I noticed the phone was water damaged. Replacing the parts fixed the power button, but the back camera still doesnt work.
The u3200 chip and that area had a slight bit of green corrosion, so i cleaned it gently with alcohol.
Nothing appears damaged, burnt, or exposed, and the board looks squeaky clean now, but even after that and restoring firmware and trying a few tricks online the back camera still comes up black and the flash wont work.
When i switch to video recording, the flash icon turns red and says the phone is too hot and must cool off for flash to work.
Any tips on how i can try and troubleshoot this problem? I have basic tools like a microscope but microsoldering is out of the question... No warranty either.
Absolutely any advice on either what component is likely the problem or what i can do or check to narrow it down would be greatly appreciated!
Это хороший вопрос?
Счет 0
2 Комментариев
My 6S Camera video recording front and back not working. Taking photos work. But when choosing to record everything seems ok but recording does not start. Tried a working front and back cameras but still not working. Anyone have a solution? ?
из
@dmd786 can you record a voice memo? Do you have any other audio issues?
из
Добавить комментарий
1 ответ
Выбранное решение
Well you will need microsoldering..
6s plus back camera has a filter between VCC_MAIN and LDO.
It needs to have continuity and providing 3.85-4.2V to the LDO.
The LDO must be outputting 2.85V.
All the connected caps must not be shorted to ground.
1V8 rail must be present on the camera connector and of course not shorted to ground.
Finally, you need to have tested with 2 cameras. Not just one. Or use a known good.
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
Daniel Rodriguez буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 262
