Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104вопросов Показать все
The display started showing something like snowflakes
Hi guys,
I have followed the exact steps of reinstalling the HD in my iMac Intel 20" EMC 2266. However, as soon as I put all parts back in, connected all necessary cables and turned on the iMac, the LCD display started displaying something like snowflakes and lines all of the time. It looks like and old time TV when your antenna is not fixed and you see the picture through snowflakes. Does anyone know how to fix that?
Thank you very much in advance.
Best regards,
Petar
Это хороший вопрос?
Оценка 1
2 Комментариев
Hi,
Can you please tell me if this was resolved as I have had this identical problem after replacing the fan.
Kind regards
из
no it has not been resolved
из
Добавить комментарий
1 ответ
Выбранное решение
The new hard drive would not do this. Please go back to the repair guide and check all the connections you touched. Check the connect on the display data cable.
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
Good to see you back +
из
I have checked all cables thoroughly. The display data cable is also connected to the logic board as well as to the display. Still the same. Is it possible that the cable is somehow corrupted?
из
Could be, visually check it for damage.
из
I have checked and checked, everything seems to be ok with the cables. Still can not figure our why it displays such a picture
из
Добавьте свой ответ
Petar будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 3,537
