I cannot get the tablet to charge. It has worked previously.
Это хороший вопрос?
Это хороший вопрос?
@winnie409 you want to start off by telling us what you have checked. If nothing yet, then you want to go ahead and use a different charger. Also try a different cable. If still no charge, try to wiggle the cable. Some of the lesser know tablets have a tendency of losing the functionality of the charging port. If none of that yields any result, consider opening up your tablet and exchange the battery and possibly the charging port. Use these guides to work on your tablet. If a new battery should not help you may need to consider replacing the charging port. Since this is not a common tablet you may have to post some images on here to see if we can help you with that. To post images, use this guide.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 199
