head lights will not work
how to get the head lights to work.i changed the switch but still no lights
Update (02/17/2017)
how to get head lights to work
Это хороший вопрос?
Это хороший вопрос?
hobeck , check to see if the headlight circuit is fused, possible blown fuse. Check to see if head light switch is getting power with DVOM,(no power either fuse blown, loose plug, break in wire,corrosion,etc.), then check to see if power is coming out of switch, if power coming out of switch, check for power at bulb sockets, no power coming from switch(switch faulty). Power out of switch but no power at socket, break in wire/ bad plug/socket. Power coming from socket check/clean contacts/replace blown bulb. Good luck.
Был ли этот ответ полезен?
raining now but i will try your solutions later. thanks for the help
I'd like to know how best to find the fuse. I've found the run/tow 15A fuse, but can't trace out the headlights to find the fuse. It's my father-in-laws 2012 Cruise Car. Headlights stopped working when he put in new batteries recently.
I have a 2004 club car it runs but I have no headlights can’t find any fuses any suggestions
Do all four lights need to be plugged in to
I
Do all four lights need to be plugged in to work.
За последние 24часов: 6
За последние 7 дней: 39
За последние 30 дней: 148
За всё время: 64,257
15 Комментариев
Hi,
What is the make and model number of your Golf Cart?
Have you checked/changed the headlight fuse at all?
из jayeff
not sure where the fuse is.there is no inline fuse that i can see
из hobeck
hobeck what is the make and model number of your Golf Cart?
из oldturkey03
i have a 2005 club car & i'm not sure where the fuse is to the headligh?
из steve
I need to know how to fix the headlights on a STAR golf cart
из sherry wade
Показать 10 больше комментариев
