no sound, although radio works
2004 Toyota Avalon JBL stereo CD turns on stations change, but no sound
Any suggestions?
Это хороший вопрос?
Any suggestions?
Это хороший вопрос?
@mssteffi start off by checking the speaker output connectors on your radio. Double check to make sure that all connections are properly made. You also want to check under the passenger seat. You will most likely find the power amp located under there. Make sure that it is connected right and all the wiring is intact. Check for any blown fuses in the fuses boxes. If yours is a stock amp check that pin 13 and pin 17 should have 12Volt. Use a voltmeter or similar to check on those. Let us know what you find. remember that a pictures is worth a thousands words. Just in case you have trouble with this, post some images with your question so we can see what you see. Use this guide for that.
Был ли этот ответ полезен?
many thanks no idea there was a power amp under the seats wow
I found my speaker in the trunk had no connection on one side of the speaker wire hopping that was my problem . Soldered it back onto the speaker . Still im searching
Most likely your amplifier. Check under your passenger seat.
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 51
За всё время: 4,022
