After replacing ipad glass does not work
after replacement of the ipad touch screen does not work. I connected it to compiuter and recognizes him. I checked all the connections and everything seems in order. could you suggest something that allows me to understand where is the problem?
Это хороший вопрос?
Счет 0
2 Комментариев:
Faulty iPad digitizer is most likely the case. Were you testing it while plugged in but not installed?
из
How about the connector? No damaged pins?
из
Добавить комментарий
