Canon EOS 5D Mark II — это полнокадровая цифровая зеркальная (DSLR) камера с CMOS-матрицей разрешением 21,1 мегапикселя и функцией видеозаписи.
How to replace usb port
how to repalce usb port
Это хороший вопрос?
Счет 3
1 Комментарий
Thank you very much, Pfaff, for your kind response. I agree that sending to Technical Service will be the best.
But I'm in a hurry in the middle of a project and no time left.
Will go ahead with your so clear instructions.
Many thanks.
Dick
из Поделиться
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@dicktracy ,Dick, This is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a couple links to a tear down guide/vid to get you inside the camera to check the charge port and will also post a link to video showing what is involved in repairing a mini USB attached to the board( not your device, will show what is involved). If not wanting to do the repair yourself have a good camera/computer/cell phone repair shop have a look and estimate repair. I have a feeling the camera shop would tell you to replace the whole motherboard. Good luck.
https://www.youtube.com/watch?v=UOb55J09...
Замена передней панели Canon EOS 5D Mark II
https://www.youtube.com/watch?v=XgGkCjNS...
Был ли этот ответ полезен?
Счет 4
1 Комментарий:
@dicktracy, Dick, Your welcome, good luck with your device and thanks for posting back.
из Поделиться
I also had this problem, had it quickly repaired by these people:
https://www.fantastecne.com/repairs
Got it done very quickly and also had camera cleaned and serviced
Счет 0
2 Комментариев:
How much did it cost then?
из Поделиться
How much did they charge?
из Поделиться
Добавьте свой ответ
Dick Tracy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 23
За все время: 5,090
