How to fix 1907FPc 19" LCD Monitor feet from tucking?
it is stuck in the bothom
Это хороший вопрос?
Это хороший вопрос?
RENX , Check to see if there are removable plastic caps covering up screws that could be tightened to stop the screen from tilting. I had a stand that would keep tilting down on me and I wrapped a large an elastic around the hinged joint giving the problem and it worked. Good luck.
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 18
За всё время: 257
1 Комментарий
What is "tucking" and can you elaborate more on your problem
из Cameron
