Does this phone is going to work after the screen/cristal is broken?
I'm interested in know about what phone brands/models work after the screen is broken. For example: the Iphone works even with the screen shattered.
Это хороший вопрос?
Это хороший вопрос?
It really should still work if you drop it and crack the glass. However, if you damage the digitizer or the LCD then your screwed and it will no longer work correctly. But If the glass is just broken you should be ok. Also iPhones sometimes do stop working when dropped if their LCD or digitizer is damaged. But as long as if you drop it and only the glass breaks you should be fine.
Or here's the best option DONT DROP IT. Or at least put a case or screen protector.
Hope this helps!
Был ли этот ответ полезен?
Thanks for the quick answer. But, actually, there are phones that work and phones that don't work after the slightness crack in the crystal so, just for clarification, LG g5 is the type that works after getting a crack in the front crystal?.Are you certain? I Ask because the NExus 4 (LG) was on the not-working side.
Thanks in advance
Im not exactly sure but it is a new lg phone and they are normally relatively durable
It will still work if the lcd screen is still displaying the image normally. Also, the touch digitizer is built in with this phone, and if either one is broken, you will need a whole new lcd replacement. You can get it repaired here: http://www.ebay.com/itm/LG-G5-Cracked-Br...
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 97
