Xbox One Stereo Headset, model number B00IAVDQCK. Released March 2014, compatible with the Microsoft Xbox One. Headset includes over-the-ear fabric ear cups, unidirectional boom microphone, and detachable headset adapter with volume and mic controls.
Jack is bent, is there any way to fix it?
The jack on my turtle beach headset is bent, is there an easy way to fix it or somewhere I could take it to get fixed?
Это хороший вопрос?
Счет 5
1 Комментарий
I have the same problem. I was listening to music when I dropped my phone sideways and the wire bent. I currently can’t afford new turtle beach headphones so I’m using them while it’s bent. If anyone can fix this god bless them
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
the piece that is actually bent , is down inside the molded boot of the cable. there are replacement three ring 3.5mm jacks that you could, replace that one with, if you can solder.
OR, i am sure any local computer / phone repair shop would be able to put a new jack on that for you.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
Hey um how much does that usually cost?
из
Yes there is a way you just bend it back it won’t brake it or anything it will be back to normal.
Счет 0
1 Комментарий:
I have the same problem but I tried it but it never worked
из
Добавьте свой ответ
Jacob буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 46
За всё время: 3,990
