iPhone 7 home buttun wont work
why my iphone 7 home button wont work after replace battry?
Это хороший вопрос?
Это хороший вопрос?
Did you remove the ribbon cable, found in [недействительная ссылка на руководство] and if so have you made sure you reattached it correctly?
Был ли этот ответ полезен?
Do a restore, if that does not work the phone is dead, only Apple can fix it.
you probably broke the home button extension cable when disassembling. It doesn't take much to rip this fragile cable.
Check to see if its ripped. If so you'll need to replace the backlight film (includes 3d touch, and home button extension cable)
have you turned the phone off before doing the disassembly work? this blog shows some reasons why home button not working https://www.etradesupply.com/blog/why-to...
Watch this Video for more Information about the iPhone 7 Homebutton:
If you broke the home button extension cable you'll need to replace the backlight. Like in this Video:
https://youtu.be/W1sQ0cl1oYc (German Version)
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 243
