Black wire on control board
I took off the water /ice dispenser control board to clean the dispenser . There's a black wire attached to the board where does the other end go to
Это хороший вопрос?
Это хороший вопрос?
Hi,
This link may be of some help in solving your problem, if you can read a wiring diagram that is.
Был ли этот ответ полезен?
It some how got set to floor model/show room mode.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 15
За всё время: 459
2 Комментариев
Missy, add your make, model and model#, was the wire ripped from a connection or is there still a connector on it. this info. will help ifixit volunteers to answer your question more effectively. Good luck.
из L Pfaff
It's a GE gfe28hmhees french door bottom freezer. The connector and wire are attached to the control board. I have no clue where the other end with a connector goes
из Missy
