My lenovo a6000 cant power on
I have a problem with my lenovo a 6000, the phone cannot turn the power on but still ok with charging. I have check the battery and the condition is ok . Anyone can HELP me to solve my problem?
Это хороший вопрос?
Это хороший вопрос?
On a lot of the lenovo tablets and phones there is a reset button in the SD card slot you will need to reset it. Not sure on your model but its worth a look . If theres not one then try removing the battery then leave it sit for an hour and then put the battery back in and reboot the phone . While you have the battery out it wouldnt hurt to check the battery with a multi meter against the power out specs listed on the battery. Hope this helps
Был ли этот ответ полезен?
Muito bem gostei
За последние 24 час(ов): 2
За последние 7 дней: 9
За последние 30 дней: 28
За всё время: 7,744
4 Комментариев
Does the phone instantly shut off when you unplug the charger? If so then the battery is probably unable to hold a charge and needs to be replaced,
из Jacob Micallef
My Lenovo A6000 shutdown on recovery mode .. now dosnot turned on ..wht can i do ??? Plz help
из Akshay panigrahi
из Golu Kasar
Esta tudo bem sta vez,
из Masawa Luis
