Troubleshooting and repair information for the ASUS ROG G751 gaming laptop. Released in 2014.
Disassembled ROG G751JL and now Screen is "Dead"
I did this as a screw got stuck in the CPU fan. After the fan was saved, I started reconnecting everything back. I turned it on and noticed that the screen wasn't turning on anymore. However, I can still connect to an external monitor and everything works fine.
Going into Device Manager, I can see that the monitor is shown as working properly but it may not be getting power? Any ideas?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Did you damage anything in the process? Remove and plug back in the display cable and see if it makes a difference.
Был ли этот ответ полезен?
Оценка 3
6 Комментариев:
I found out what happened. The North Bridge on the motherboard popped. RIP.
из
Rip man, you can still use as a desktop though
из
Nah I can't lol! That's the North Bridge! Without it nothing communicates with each other.
из
? You said it worked with an external monitor
из
It did. North Bridge was faulty, causing the issue. It finally killed itself haha.
из
Показать 1 больше комментариев
Добавьте свой ответ
thehumanslayer12 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 6
За последние 30 дней: 7
За всё время: 221
