The ASUS ROG G751 gaming laptop. Powered by the quad-core Intel Core i7 processor and NVIDIA GeForce GTX 965M graphics card with TurboMaster. This Laptop comes with dual fans, copper heat sinks and a 17.3 IPS anti-glare display. The Republic of Gamers mask logo is located on the back of the screen in red.
18вопросов Показать все
Disassembled ROG G751JL and now Screen is "Dead"
I did this as a screw got stuck in the CPU fan. After the fan was saved, I started reconnecting everything back. I turned it on and noticed that the screen wasn't turning on anymore. However, I can still connect to an external monitor and everything works fine.
Going into Device Manager, I can see that the monitor is shown as working properly but it may not be getting power? Any ideas?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Did you damage anything in the process? Remove and plug back in the display cable and see if it makes a difference.
Был ли этот ответ полезен?
Оценка 3
6 Комментариев:
I found out what happened. The North Bridge on the motherboard popped. RIP.
из
Rip man, you can still use as a desktop though
из
Nah I can't lol! That's the North Bridge! Without it nothing communicates with each other.
из
? You said it worked with an external monitor
из
It did. North Bridge was faulty, causing the issue. It finally killed itself haha.
из
Показать 1 больше комментариев
Добавьте свой ответ
thehumanslayer12 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 178
