Absolutely no sound from Ipad 2
After battery, digitizer, and widi antenna replacement sound no longer works from headphone jack or speakers
Это хороший вопрос?
Это хороший вопрос?
Try cleaning the charging port, sometimes it gets oxidized and gives such fault. If you can replace it with a working one it would be even better.
Был ли этот ответ полезен?
I will try a new chare port
Unfortunately that did not seem to fix the issue. I ordered new speakers and headphone jack assembly
I'm a bit skeptical that will fix the issue, but there isn't much else left apart from a problem on the board itself. Hope you will succeed.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 812
1 Комментарий
Did verify conn before putting digitizer on
из Bradley Crawford
