Документация по ремонту и сервисная информация для телевизоров Hisense.
Replacement Screen / Panel for 55H7B TV
I had a CD tower fall on my screen, no idea how as no one was in the room and it wasn't affected by prior earthquakes, effectively killing the TV. I am needing to replace the screen and have already tried through Hisense support without avail.
Any help would be greatly appreciated.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
It might be cheaper to get a new tv as displays for tv's can be very expensive and at that point, its almost the cost of a new tv, plus you have to take apart the tv and not damage anything. So best suggestion is to get a new TV.
Был ли этот ответ полезен?
Счет 0
4 Комментариев:
Understood, but I want to check into the option and determine for myself.
из
I cant seem to find one, like i said they are hard to find and if you can, they are expensive
из
That's been my issue.
из
Well the best option is to just get a new tv. Displays like i said are near impossible to find and if you can by some miracle, they are expensive. The best bet is to open the tv, and get the model number of the screen its self, and then search for that, its your best option
из
Hisense does not offer replacement screens nor do they source it out to anyone, as I found out by contacting them directly.
Счет 0
1 Комментарий:
@tvpoor that is correct :) The only way to replace the screen is by trying to find a panel from a otherwise bad TV. Try a search based on the model of the panel vs. the TV. On the back of the panel should be a label that identifies the panel. Use that number to search for a replacement.
из
Добавьте свой ответ
Ted буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 698
