This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355вопросов Показать все
The light keeps flashing on different camera settings
I dropped my instax mini 8 and now the lights on the settings keep changing. I was in my room and the light should have been telling me to use the house setting but it kept changing to the other settings. I was wondering if there is any way to fix it so that my camera tells me the correct setting to use. If not, any tips on which settings to use and when would be useful. Thanks.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi Carrie, one of the common fixes for the flashing lights is to replace the current batteries you have with AA LR6 Alkaline batteries.
-Let me know if this helps.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Did you manage to resolve this I have the same problem
из
Only 3 of my lights are blinking and they are orange and the home is orange and not blinking and I change the battery
Оценка 0
3 Комментариев:
I have this problem too
из
I have this problem too. Lights blinking, I did change the batteries, and nothing. Only blinking lights.
из
из
Добавьте свой ответ
Carrie Liu будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 18,885
