Repair guides and support for the fourth generation Forester, a compact crossover vehicle manufactured by Subaru.
4вопросов Показать все
My fuel door doesn't pop open, it just barely opens?
How can I fix my fuel door so it pops open far enough for me to put my finger behind it? Right now it just unlocks and I have to very carefully coax it open.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hi,
It may be either the fuel door spring is loose, has lost tension (try bending it out a bit to increase tension), is 'missing' or it could also be that the fuel door hinges, spring or release mechanism could do with some lubrication.
Here is a link showing the fuel door spring. If not in the USA you may have to contact a local dealer regarding the part.
Hopefully this is of some help
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
H.L. Todd будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 339
