Chevrolet Malibu — среднеразмерный автомобиль, выпускавшийся Chevrolet с 1964 по 1983 год и с 1997 года по настоящее время. Malibu начинался как комплектация Chevrolet Chevelle, а в 1978 году стал отдельной модельной линейкой. Изначально это был заднеприводный автомобиль среднего класса, но в 1997 году GM возродила марку Malibu уже как переднеприводный автомобиль.
How To Replace MAP Sensor?
I'm a pretty handy person. I've been getting the "SVC ESC" error message and the check engine light on my 2012 Chevy Malibu LT 2.4L, along with rough engine idle. After doing my homework I need to replace the MAP sensor. I figure easy enough, problem is I have a vague idea where it's located. I've scoured the net trying to find something solid whether a youtube video or forum with some sort of way to pin point or show me the location and a possible how to access the place if not easily obtainable.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
pierce2784 @lpfaff1 has answered the MAP however to address the "SVC ESC" error is a different story . This stands for service electronic stability control. this could be caused by a host of things. If you have access to a OBDII with ABS functionality you will find it a great asset in diagnosing the problem . If you have an ABS light on at the same time it could be anything from dirty tone rings to metal filings sticking to the sensor head. It can also be the ABS pump not functioning properly or something as simple as the yaw sensor. Some cars have this located under the passenger seat and occasionally if something gets jammed in under the seat it can affect how it works. It can also be caused by bad struts, a loose swaybar ,bad wheel bearings , seized brakes .or a faulty steering rake. Its hard to narrow it down without a proper inspection . Hope this helps
Был ли этот ответ полезен?
Счет 2
4 Комментариев:
Thanks @jimfixer , I was reading up on the SVC ESC error and you beat me to it, good assist, thanks again.
из Поделиться
@lpfaff1 always happy to help out . I kinda wondered if you were finished there or not .
из Поделиться
@jimfixer , Some times I get reading and one thing leads to another(time flies). thanks again.
из Поделиться
@lpfaff1 Watch what your answering tonight theres student out on the forum . I just trolled one by accident Why can't I connect to my printer?
из Поделиться
pierce2784 , replace the MAP sensor. link below may help, 2nd link is the replacement sensor to aid in what to look for. See below for SVC ESC error info. by Jim. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=OMmrjtDg...
http://www.jcwhitney.com/1997-2012-chevr...
Счет 2
Добавьте свой ответ
pierce2784 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 35
За все время: 8,103
