Nikon N80 (также известная как F80) — это 35-мм зеркальная фотокамера. Она была выпущена в январе 2000 года и идентифицируется по номеру модели 1776.
Is it a brick?
Hello!
I just bought a used Nikon N80. It seemed to be in perfect condition, but I took it home and discovered a focusing problem.
The image in the view finder is dim. And when I try to focus, the lens goes in all the way and back out to infinity without finding a focus point.
I tried a few lenses with the same result.
I checked the sensor at the bottom of the chamber, and it's clean.
Like I said, the camera seems to be in great condition otherwise.
What do you think? Is this a brick, or can I fix it?
I should also mention that I bought the camera with the lens improperly attached. I had to carefully cut a tiny piece of plastic off the lens mount to get it off.
Fortunately I paid only $20 for it, plus new batteries.
Thanks for any input on this!
Eric
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Eric Zulaski I wonder if you have trouble with the AF unit or if an adjustment would work. Since you are only in for $20 it maybe worth your while to get the repair manual from this page (under "Document") and go through the adjustment routines etc.
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
Thanks for the tip. I will certainly give it a try.
из Поделиться
I had been on the guide page, but I didn't notice the repair manual tucked in there.
из Поделиться
It's a present added after you asked the question
из Поделиться
Добавьте свой ответ
Eric Zulaski буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 31
За все время: 617
