The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
Defective Xbox One Controller?
My Xbox One Controller will not turn on. I have tried very simple answers like changing the batteries, but it still won't turn on. I don't recharge old batteries or anything of the sort. It just won't turn on.
Это хороший вопрос?
Счет 0
1 Комментарий:
What occured before this happened? Any liquid damage? Did you get this new or used? How long have you owned it?
из
Добавить комментарий
1 ответ
Check the solder points
Был ли этот ответ полезен?
Счет 0
7 Комментариев:
What solder points? Where? How do i open the controller?
из
Why are you following me wherever I answer? This isn't your question
из
Because yoru answers aren't very good. Im sure @mayer can back me up on this. Your also not being polite
из
Cameron. Why not just answer the question correctly, give a link on how to identify and repair cold solder joints. Also advise on how to diagnose. He does answer a lot of questions poorly and incompletely. Remind you of someone that did the same thing when they started?
из
@mayer Yes. But also im trying to help him like you helped me.
из
Показать ещё 2 комментариев
Добавьте свой ответ
Spencer Rinder буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 282
