rear passanger elictric window dosent work
window wont work n/s/r makes noise
Это хороший вопрос?
Это хороший вопрос?
What is n/s/r ? If you hear noise from the motor or the window then the issue is the window regulator itself . Probably the gears are stripped or the window has come off the track . you will need to take the door panel off and inspect the regulator.
This video will help with the removal
https://www.youtube.com/watch?v=MCN_2hcW...
Hope this helps
Был ли этот ответ полезен?
N-S-R Near-side rear, passenger side rear
A lot of these cars now have a cable system and plastic parts I've replace a bunch on Chevy and ford
Thank you @mayer
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 88
1 Комментарий
Hi Simon, have you checked the fuses?
из Blake Klein
