Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
494вопросов Показать все
Push Pedal nothing happens
Yesterday I pulled up to my ball and hit it and then got back into the cart and it wouldn't go anywhere when I press the pedal I have a 2000 ezgo electric golf cart. I haven't checked anything I just want to know where to begin .
Это хороший вопрос?
Оценка 10
1 Комментарий
I drove my cart over a stick I didn't realize was attached to a larger branch, and somehow it disconnected the pedal. Now I need to know what to reach in and try to reconnect. Is there a diagram somewhere? The cart is currently stranded on a path in the woods above my house, and winter is coming.....
из
Добавить комментарий
7 Ответов
Выбранное решение
@vxseanjohnxv ,Sean, Check all batteries for full charge(replace if batteries will not charge/hold charge) and that the wires/connections are clean/tight and undamaged. There are a few other things that may cause this issue faulty solenoid, key switch, micro switch, faulty motor,etc.. Find links below 1st and 2nd link are trouble shooting links for your issue and the 3rd link is a service manual with trouble shooting/testing components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.cartsunlimited.net/ezgo-troub...
http://www.buggiesgonewild.com/electric-...
http://products.jacobsen.com/img/manuals...
Был ли этот ответ полезен?
Оценка 6
5 Комментариев:
I have a Yamaha 48volt golf car and batteries are fully charged and drove it 10mins and it shut off switched tow tow and back to drive and and it a little bit any one have any ideas
из
Can someone please help
из
Hi, we are having the exact same issue with our cart did you find a solution?
из
Check if it is actually charging. When you reset the system with the switch under the seat, the charge meter resets to show full charge but, it may not not be fully charged at all.
из
Hey I have a 48 v EZGO, purchased 6 New Batt, continued to do the same thing. Had the Ipswich replaced worked fine for 2 weeks. Now it’s back to me pumping the pedal about 10 times before it moves?????? Help please Jimmy Woodard
из
What are carburetor brushes? On an electric cart?
Оценка 1
2 Комментариев:
What else could it be
из
Carburettors do not have brushes. Carburettors are on gas carts. Brushes are for electric carts.
из
everything was working normal yesterday but today, i pushed the foot feed and there’s nothing. i did put in a new solinoid could it be bad? we bought all new batterys less then a year ago so they should be good
Оценка 0
1 Комментарий:
My ego is gas
из
Carbuerator brushes where my issue
Оценка 0
1 Комментарий:
There is no carburettor on an electric cart. Carburettors supply a mixture of fuel and air to the engine in a petrol engine.
If you had brushes fitted it would be an electric cart.
из
2013 Yamaha electric golf cart push the gas pedal real slow and the car will go but if I push it fast to the floor the cart would just shut down and I have to disconnect the battery or disconnect a controller switch and reconnect it to reset itself
Оценка 0
1 Комментарий:
You can reset the system with the rocker switch under the seat on the back wall high up. it is a little hard to see. Turn it off for a few seconds and back on again.
This has the same effect as disconnecting a battery lead but much eisier.
из
Everything has power on my 2001 ez go golf cart everything is new but when I hit the gas pedal it dont move
Оценка 0
2 Комментариев:
I have a 1998 ezgo gas txt same issue solenoid is clicking but motor isn’t turning over it has a new solenoid and new rectifier. What else could it be
из
Starter/generator may need rebuild (new brushes and cleaning) or replacement.
из
Have a electric 2000 yahma golf cart Selenoid does click when I push the foot pedal
Оценка 0
Добавьте свой ответ
Sean Cowan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 51
За последние 7 дней: 300
За последние 30 дней: 1,101
За всё время: 152,101
