Repair and disassembly guides for the Jura (Capresso) Impressa Series J coffee maker.
Coffee beans in coffee bypass
Aged mother poured coffee beans into coffee bypass. Now what?
Это хороший вопрос?
Счет 1
1 Комментарий:
dude your aged mother is killing your machine. First of all, forbid access to not make problem worse! What's next? She'll put eggs there thinking it's a blender. seriously.
secondly, it's best to take the beans out. the way it works is it directly puts the ground (in your case not) beans into the brew assy. There's a piston w/ a metal filter. If you run as is it could bend the metal part.
Turn the machine upside down and give it a good shake. That's the lazy way.
If you wanna be thorough, take off the brew group and empty it out by hand. This way you'll know for sure it's empty. If you not lazy, good chance to clean it. It's prolly disgusting, as you'll see.
из
Добавить комментарий
1 ответ
Open it. Jura Capresso IMPRESSA J5 öffnen. Clean it.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
hopskater буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 291
