The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
167вопросов Показать все
I have pushed very hard a a needle in the top microphone hole
Hello.
I wanted to take out the sim card of my galaxy S8+
I made a mistake and i put a needle in the top microphone hole. (the one next to the sim card hole)
i pushed the needle very very very hard... until i see that it was a mistake.
Do you think this could cause damage to the microphone?
Thank you for your answer and sorry for my bad english.
Это хороший вопрос?
Оценка 1
1 Комментарий
Any news on this?? I'm afraid I just did the same thing
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I would say theres a very likely chance you damaged the microphone if not something else
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Thank you
is there a way to check if it is damaged or not ?
из
Its not an easy one but recording a video with audio may show any problems. That top mic is also used for noise cancelling which isnt so easy to test
из
I did the same the first time I got it. Mine still works. Tested it using the Voice Recorder interview option which uses both microphones. Then I spoke at the top one and then at the bottom one in roughly the same dustance and loudness.
Оценка 0
Добавьте свой ответ
Parisien будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,897
