Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
Front facing camera replacement
Hi there
I need to replace the front mic of an iphone 6s plus. I suppose that I need to replace the camera and everything at the same time. Would the camera form iPhone 6s work?
This one here: iPhone 6s Front Camera and Sensor Cable
regards
Frímann
Replace a front camera and sensor cable assembly compatible with the iPhone 6s. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00123-01. Изображение
Товар
$22.99
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
laukur, Directly from your link in your question. Compatibility of iPhone 6s Front Camera and Sensor Cable, Item code: IF314-015-3 for All iPhone 6s , ((Not iPhone 6, 6 Plus, or 6s Plus)).
As far as having to replace the camera because you need to replace a bad mic. which is part of the lightning assy., camera should not have to be replaced unless defective.
Lightning Connector Part Assembly includes:
Lightning connector
Dual microphones
Headphone jack
Links below are for replacement part and guide for installation of the Lightning Connector Assy..
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iPhone 6s Plus Lightning Connector and Headphone Jack
iPhone 6s Plus Lightning Connector and Headphone Jack Replacement
Replace a battery compatible with iPhone 6s Plus Models A1634, A1687, A1690, and A1699 smartphones. Part #821-00126-A. Изображение
Товар
$24.99
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
TL:DR You need to use the 6s plus front replacement camera.
The normal 6S front cam will not work.
из
Hi and thanks for your reply! However I think there is some misunderstanding. It's the front mic by the earpiece and close to the front facing camera (facetime camera often called) that is broken. I believe your directions were for the mics at the bottom of the phone (by the headphone jack)
Regards
Frimann
Счет 0
Добавьте свой ответ
laukur буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 157
