Why will it stop moving after about 5 mins?
Why does it stop moving after 5 mins ?
Это хороший вопрос?
Это хороший вопрос?
rsb24, Drive belt belt may be worn, loose or broken(missing a chunk out of it), idler pulley seizing/weak tension spring, if hydro drive-low on hyrdostatic fluid/oil, air in hydro. system. Links below may be of help in trouble shooting also, 1st link is the service repair manual and 2nd link is your owners manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 66
2 Комментариев
rsb24 what do you mean by stops moving? It stalls? It totally dies or just stops moving but keeps on running? Does it ever start to function again? When? How?
из oldturkey03
It stops moving, stays running, doesnt matter if your mowing or not.
из rsb24
