Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
ear speaker not working after screen replacement
Hi i had issue with iphone 7 plus after replace screen client came back and said ear pice not working i bought ear pice and few flex cables and replaced as every one said 1 flex cable ear piece is working no camera 2 nd flex camera works not earpiece any solution????
i have tried hard reset
i have tried replace flex cable
i have tried little tape inside
Please help
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Are you getting parts for a reputable seller? It sounds to me like the part you are trying to replace is faulty and the replacement parts are not that good. Some functions are working and that is good letting you know that the hoard is fine. This is because you say it works with one cable and not the other. I would like at find a replacement for a reputable seller such as iFixit.
iPhone 7 Plus Front Camera and Sensor Cable
Simply use the same ear speaker that you know is working. This should solve you problem. Also makes sure the cable is lined up perfectly making contact with all the ear speaker connections.
Replace a front camera and sensor cable compatible with the iPhone 7 Plus. Includes the front-facing camera, one microphone, and the proximity sensor. Part #821-00519-03. Изображение
Товар
$29.99
Был ли этот ответ полезен?
Счет 1
As the iPhone Guy suggests, you need known working test parts to effectively troubleshoot. Then once the problem is found you can just replace the faulty part.
Счет 1
2 Комментариев:
It's finally fixed by the 4 th cable replacement
из
So basically it was the bad parts
из
Try another flex or an original flex a lot of those flexors are bad from the factory
Счет 0
Добавьте свой ответ
Vihar Patel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 2,741
