Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
494вопросов Показать все
club car wont move
48 volt club car, surges slightly when pedal is pressed, but will not move. can hear silenoid clicking on and off after a few seconds of pedal release, but no movement in forward or reverse.
Это хороший вопрос?
Оценка 13
19 Комментариев
steve any more information on the exact model or year of your cart? This could be a lot of things including your multistep potentiometer, bad batteries (check to make sure that all the batteries are working)and plenty more. Start with the batteries.
из
it is a 1996 48 volt club car. It was running fine then stopped operating while we were riding it. I measured just over 50-volts on the batteries (2 year old batteries) and cannot see any loose connections. I turn on the key and switch to forward or reverse, hit the pedal and ca hear a click from a solenoid, the a very slight movement as if the car wants to go but won't (very slight for 1/2 a second). when the pedal is release, a few seconds after I can hear the solenoid click again.
из
48-volt powerdrive plus
из
Our 2001 club car is doing the same. Did you ever find the solution?
из
Yes mine turned out to be a failed computer. I had it replaced and it has been fine ever since.
из
Показать 14 больше комментариев
Добавить комментарий
6 Ответов
Наиболее полезный ответ
Sounds like the motor is not getting all the voltage it needs to move. Check your connections at the solenoid and the motor. If you are not getting enough voltage at the solenoid, check for bad fuses or circuit breakers. If voltage is good at the solenoid, but not the motor; suspect the solenoid is going bad. Hope this helps.
Был ли этот ответ полезен?
Оценка 4
4 Комментариев:
If its the solenoid, what are the repair costs?
из
What is the cost if it is solenoid
из
The golf court moves and the next time I get in it it won’t solenoids,a noise click a day later I get in and it move and go to store and won’t move
из
Have you figured out what was wrong with yours?
из
I had a similar problem. After I cleaned up the battery posts the cart worked fine.
Оценка 2
Generally the MCOR or the Computer
Оценка 1
1 Комментарий:
04 /48 volt club car-reverse only/no forward/replaced one of the micro switches/good to go!
из
2007 Club car had sat two years. Went through and cleaned all the cable connections, was able to get the batteries charged but the car would not move, but I could hear the solenoid clicking. With the gas pedal depressed, key on and cart in forward, I banged on the bottom of the rear solenoid and away we went. Been fine ever since. I imagine the solenoid was stuck somehow.
Оценка 0
Replace Mcor under the pedal
Оценка 0
1 Комментарий:
What is a mcro?
из
I had this exact problem replaced a few things (don’t want to get into it) but it ended up being a simple fix, the positive cable going off the batteries was visually fine but when I jiggled the cable while pushing on the accelerator the connector sparked. After inspection I noticed the wires inside were frayed and corroded so I replaced and works fine now.
Оценка 0
Добавьте свой ответ
steve будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 110
За последние 30 дней: 366
За всё время: 78,354
