How to clean the dust inside of lens
How do you clean the dust inside of lens?
Это хороший вопрос?
Это хороший вопрос?
Dust rarely affects photos - if it does, it’s minor. In addition, you’re risking the entire camera over a little bit of dust.
You’re better off living with scratches and internal dust, rather then trying to fix it and risk ruining the lens and needing to replace the lens - or potentially the camera. With dust it doesn't affect resale as it's a common non-issue, but scratches that affect little to none of the final photo mean you can get a good deal on a nice lens or camera if you're able to test it and make sure it's not in a high impact area.
Был ли этот ответ полезен?
Hello
First cotton buds and spray air duster and is done ✅
Good luck
Never use cotton balls on a lens! Lenses are extremely fragile, so you must think of something like cotton balls like fine grit steel wool. Canned air is fine as long as the gas liquid does not settle on the elements.
Yes you are right
Good luck
Still doesn't answer my question, how do I remove the lens to clean the dust out from the inside????????
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 11
За всё время: 2,827
4 Комментариев
Is the dust on the lens glass or actually inside the lens?
из George A.
I have the same question and mine is on the inside of the lens
из Cristallia XD
It's inside the lens
из Daniel Barnes
Well, to tell you the truth, I don't know. This is a tricky one. Try zooming in and out as fast as possible while shaking the camera to try loosening the dirt. If you have access to an air compressor, blow the lens out around the outside.
из George A.
