Flickering when low light
How to solve plssss my j7 flickers when on low light how to fix help me pls should i replace the lcd or their is other things to replaced or it just needs something to be solved ?
Это хороший вопрос?
Это хороший вопрос?
@kobexkyrie seems to be a very common issues with this model. It is the backlight that is flickering at higher/lower power demands. Could be filter or power IC as well as the Amoled. Take a look at Flickering screen on low back light and see if some off that will work for you.
Был ли этот ответ полезен?
Sir what do you mean of off ?I just updated the model than it started flickering
@kobexkyrie of off ? I was stating that this seems to be a common issue with this model phone. Check the answers on the link in my answer to you. Click on the light blue writing :-)
Thanks for the help it helps me a lot to save
Sir unluckily it didnt work even the screen filter doesnt work also what should i do
I replaced with new battery and problem went away.
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 24
За все время: 17,574
1 Комментарий
my samsung J7 camera light cannot go off. steady ON
из Philip Onyia Поделиться
